Nope, but you'll need to put longer brake hose on the rear above the diff as original will be on full stretch. Roughtrax do set of 3 (goodrich ones)two for the front as well(they could be tight as well) will get rid of spongey feel.Best fit free wheeling hubs to-will make cv boots last longer.Drop bracket for panhard rod to keep axle aligned with body. Bracket for brake valve which sits on top of axle-to raise it up to keep original proportioning.If I've missed anything I'm sure someone else will say.
