Headlight adjustment
  • Headlight adjustment
    Just fitted some hids and the beams a bit high. How do you adjust them down?
    GRAVITY IS A MYTH THE EARTH SUCKS!!!
    Let some air out of the front tyres ...
    PS
    You might want to check that your MoT station will give you a pass with them fitted ...
      Lift the bonnet and you'll see the adjusters on the top of the light units.
      One for up and down, the other is for side to side.
      They'll pass the MOT as long as the beams are correctly aimed.
      It depends on mood of your local Traffic Smokies whether you get pulled or not, so keep the standard bulbs in your glovebox.
        Cheers Vince thanks for your help again
        Found this as well
        http://www.hiluxsurf.co.uk/showthread.php?t=8978
