rear window maintainence
  • rear window maintainence
    are there any tips on how to keep the rear window in good working order
    Keep the runners clean and lubricated
      I took the panelling off the tailgate, sprayed wd40 on the runners and spring, then silicone spray on the rubber guides where the window edges slide in.
      Then hope the motor lasts!
      If I like it, Bushwhacker doesn't. :-)
        Yeah, it's easy, fill the ###### thing in!!! Mine's packed up again at the mo.
        It's only kinky the first time...
          From what I have seen, the most common problem with the windows, is not the motor itself, but the rubber " Cush drive " on the drive gear. On the tailgate, this can be done in situ, by just prising up the steel cover plate. On the other doors, however, the motors and winder assemblies need to be removed. Moisture gets in and causes the drive plate and spindle to rust, and the rubber drive pegs to perish , and begin to spin, losing drive. This can be changed quite easily using the " cush drive " plates from the electric windows on many of the Toyota and Lexus models. Later model Lexus's and most probably Toyota's too, have an improved design, much less likely to fail. Lubricating the window runners with clear silicon spray, and the moving parts of the winder assembly with silicon grease does help, though. Some pic's. ( Last one being the later design ).
          " Time wounds all heels ".
            Mick,
            Do you know if it's the same or similar set up on the 3rd gen? Mines a bit creaky, and you know if/when it dies, it'll be whilst open
            Rog
              Originally posted by fsaroyster View Post
              Mick,
              Rog
              Hey Rog. The third gen doesn't suffer as much. It's an up and over, and the window doesn't get lowered as frequently, resulting in them lasting a lot longer without giving up. I'd just try and spray the window runners with silicon spray, and see how it improves. Doing a search on Yotatech might yield more info.
                Cheers Mick, I'll take a look at the weekend hopefully...
                Rog
