Brake upgrade?
  • Brake upgrade?
    Hi all
    Does anyone know if the brakes on a 2nd gen surf can be upgraded from another Toyota or lexus for example?
    ALL THE GEAR!............no idea!
    Originally posted by zem_41 View Post
    Hi all
    I'd like to know this, as the brakes on my surf are pretty crap, even after replacing the discs and pads.
    If I like it, Bushwhacker doesn't. :-)
      You need to replace the (probably) 10+ year old fluid.
        Hi all
        http://www.europerformance.co.uk/pag...rontbrakediscs
          Nothing wrong with the late LN130 and the KZN130 brakes if working properly. Maybe adjust your driving style if they're not good enough for you.
          Nev.
            if susp. lifted adjust the lsv
              It's been said by quite a few people, and I intend to try it at some point, that EBC " Green " front pads are an effective, and inexpensive upgrade. What Vince says about the fluid, and J.C says about the LSPV are also very true.
              " Time wounds all heels ".
                Cool cheers lads
                I think the ebc idea and the vented grooved disks are the way forward.
                As Im probably gonna put the v8 in I think a brake upgrade will be required.
                And the fluid too
