Right then, torsion bar madness in this heat has me wondering about my wander.
Hiluxes often lean a little to the right (not nazi style I hope) to do with the fuel tank and the driver... So when I wound up my torsion bars I wound up the right side a little more to compensate. Ever since it's pulled a little to the right - more so at speed. I could def replace the rear shocks, the front are new rancho 2'' jobs.
I've only just thought this could be the cause. But maybe it's just the heat. Tyre pressures all good, tread and make and size the same.
Opinions on this theory would be good..........
Basically uneven torsion bar pressure affecting ride?
