yes i got those disc that vince told me but a week later found this brembo brand new for 30 quid, so i choose them to keep on moving the project,
got the calipers of the citroen, the one with the yellow sticker(i got rid of them), i got hold of a set of rear calipers of a jaguar s type 03, that's the other one you see in the pic, got 30mm spacers, and it will accommodate well in a 16 inch wheel, now i need to figure out how to rout the handbrake cable, any ideas? and need to make the bracket to support the caliper.
i had few minutes to play with this; this morning.
what im trying to achieve its to use the same handbrake system ((brackets) but in different position, that will make easier to connect the handbrake cable.
this is the jaguar S type calipers, and im rotating the brackets about 90 degrees
drilled another hole, had to be countersink, otherwise the rest of the mechanism wont fit
and i need to keep the old bolt on place, that's to stop the mechanism overdoing it
it need a lock nut
to be able to grind it to shape
fitting in the bracket
and making sure that after grinding to shape the bolt all fits right
then fitting the rest of the brackets for handbrake to make sure that all work well before dismantling it and paint it, by the way this is the left hand side caliper
got hold of a set of rear disc brakes of a 01 nissan patrol, and they fit perfect without the need of grinding or modding the shaft.
