Wind deflectors removed
  • Wind deflectors removed
    Took deflectors of but it's left all the adhesive on the doors any idea our to remove the stuff with out damaging the paint work regards kc 60
    Get any loose bits off with fingers or rubbing with a soft cloth, then use petrol to remove any sticky stuff.
    well, that was a bad idea!
      annoyingly someone removed mine before I bought the truck, and took the paint off with it!
      If I like it, Bushwhacker doesn't. :-)
        Tried petrol,nail varnish remover,thinners , I'm lost now blow torch comes to mined only joking but the old gal looks a mess now . I really need help now ,not a clue what to use next ,read lots of threads on site sore eyes and finger tipsRegards kc60
          Wafting a blow torch on it should slowly heat the adhesive so it will come off.
          Or if you want to be safer...a hair-dryer.
            Tried WD-40?
            Eat.Sleep.Surf.Repeat.
              a blow torch sounds hairy
                'Caramel' wheel.
                  Any of these may Help ...
                  http://uk.search.yahoo.com/search;_y...fr=yfp-t-702-s
                  Good Luck
                  11+ Years of Surfs ..... n Faultless to a "T" is my Yota !!
                  Buncefield Burner
                    http://www.youtube.com/watch?v=pgSiqcaBbSM
                    Alan
                      A big thank you to all
                      Thanks for all your help going to try autoclem tar remover first then work my way to all the other good suggestions,Been on call so no time to try before regards kc60
