If so, I have some questions for you..
Does anyone know owt about Cam Phase Valves?
Its on the Astra... its a 1.8 petrol and it sounds like a diesel - very clanky.
VX have had a look and put it down to these valves... but want a kings ransom to replace them...
Doesn't affec performance, it goes like stink, but sounds like a bag of nails.
Q's are - are they easy to replace and is my mrs gonna wreck the car driving it like this?"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
google is my friend.
4 bolts and 2 wiring harnesses.
###### rip off merchants.
http://vauxhall.workshop-manuals.com...ex.php?id=3695"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
Did the noise suddenly appear?
Check the electrical connectors on the phase solenoids are secure and the wiring is OK.
Have you got an OBD2 code reader?
New phase solenoids here.....
http://www.ebay.co.uk/itm/VAUXHALL-C...item2c684e7ebd
Originally posted by BUSHWHACKER View PostDid the noise suddenly appear?
No, it's been getting steadily worse for "ahem" months now...
Check the electrical connectors on the phase solenoid are secure and the wiring is OK.
Will do..
No, but VX reported no stored codes with their Tech2. Strange as the Engine Management Light has been on....
http://www.ebay.co.uk/itm/VAUXHALL-C...item2c684e7ebd"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
Originally posted by Wolfracer View PostCool, will have a look...
p.s. Get yourself an OBD2 code reader, they're around £50 these days plus you'll be able to use it on your truck as well.Last edited by BUSHWHACKER; 29 April 2013, 23:29.
Vince, are they the same thing? the ones in the Manual look a lot larger...
Think I'll need to get the cover off tomorrow and have a look..."B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
Originally posted by Wolfracer View PostVince, are they the same thing? the ones in the Manual look a lot larger...
Ah, just seen your link for the repair manual.
Are you sure thats the 1.8 engine in the link? It says 1.4 in the menu on the left of the page.
Originally posted by BUSHWHACKER View PostAh, just seen your link for the repair manual.
Just found this which ties in quite nicely.
http://vauxhall.workshop-manuals.com...ex.php?id=5691
Thing is the VX garage said they "modify" the new ones to prevent oil blocking them again...
That service sheet says the filter is not required after run in.... so what do they do to modify them then? stick a screwdriver through the gauze?
Gonna take them off and see what state the gauze is in first before i go any further..."B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
Cam phase variator failure is well documented in Alfa Romeo and Fiat circles. GM used re-badged Fiat engines for a number of years so it may be the same part.
If you stick to the service schedule (designed to keep the cost for the first 60k down to attract business users) the the variator will fail at approx 50- 60k If you change the engine oil every 6,000 miles (rather than 12 or 18,000) then the variators seem to last for ever.
I have had 2 or 3 Alfa 2.0 Twin Spark engines over 150,000 miles with no variator failure (or any of the other maladies these engines are supposed to suffer). Just keep changing the engine oil - just like a Surf really!
Cheers,
Mark
Originally posted by markp2 View PostCam phase variator failure is well documented in Alfa Romeo and Fiat circles. GM used re-badged Fiat engines for a number of years so it may be the same part.
Cheers,
Mark
cheers for the heads up though... gonna have a look when she gets home."B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
one bolt and they pull out....
They were a bit dirt, but not ever so.... Gauzes were all intact, so dropped the ends into petrol to clean them up.
Put them back in and...
....knock knock knock knock knock....
Apparently I have to reset the adaption values in the ECU (?)
Gonna try the old trick of disconnecting the battery overnight and see what happens...
Probably nowt but worth a shot!"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
