Oh´ and Nó need fOr that sort of fishnet on My link ´ please remove 😝🆗
ToNgfaCe
Originally posted by ToNgfaCe View PostHey Mr Surf , tis imoji keys on Iphone , not the seCret suirrel stuff , !❕❗❕©
Do You know if I can just get 2" inch raise rear springs to get the sag out the olé girl , She be good to Tow Me boat then , hope springs tufty , have read bits on this most krakin site but be good of Yá toO let Me know if Ya know bout such things , ruff trax sound best . Thanks lots 👌⚡©Originally posted by ToNgfaCe View PostOh´ and Nó need fOr that sort of fishnet on My link ´ please remove 😝🆗
I think I will try to read this again, but much later, perhaps after a few drinks.Eat.Sleep.Surf.Repeat.
§€€?"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
Originally posted by ToNgfaCe View PostOk , so i need strong springs for My Truck as the back is sagging . Please advise.
Saggy arse syndrome is not uncommon.
You could get longer springs or uprated springs.
I opted for a set of uprated springs from Millners.Eat.Sleep.Surf.Repeat.
New post chassi?
19th June 2013, 23:18 #7
ToNgfaCe
Registered User
Vehicle: Toyota 4 runner , 3 litré turbo , 1994
Chassi spring and shock plate replacement
I need help ❓
PLEASE does anyone know if and where I may purchase the plates that sit on the chassi that house the springs and shocks . I have Just put new uprated springs on and noticed that the shock that is bolted on top left side has rotted around the bolt hole and about to give way . Please ? Do I have to fabricate new ones Myself or can I buy them and just weld them up ❓
THANKS peeps ❕❗❕
4runnings the nǓtz 🏁
__________________
Everthing interesting ©Everthing interesting ©
Was hopeing for a cheaper supply ie: patent parts type of thing ❕will try photo , then see what You think ; I will describe again for now :: the rear springs of 94 4runner sit on moulded plate welded to chassie this same moulding also houses the shock top bolt that holds it on to chassie : looks like I can cut them off to replace them easy enough but It would be great if I could just buy left and right mouldings rather than try to fabricate them.
Can' t be the only olé Truck thats rotted like this ; ❓❓❓
Thanks so farLast edited by ToNgfaCe; 22 June 2013, 02:51.Everthing interesting ©
If i'm reading this right the bit your on about is part of the factory chassis build, you'd need to go through Toyota to see if this is an "obtainable" item, which i doubt, cheaper option would be to get a decent welder to make and fix a plate on,
This is the problem with 4 runners, been in this country too fecking long,Too young to die and too old to give a toss
