Has anyone with a superwinch had an issue where the winch cable suddenly gets a live feed and ends up shorting and sparking on the bumper and winch casing.
winch help
i know nothing about winches or the way they're powered, just had a thought is all.
would it be the live cable contacting the body of the winch somewhere?
it's just that for the cable of the winch to become live there must be a live cable somewhere contacting either the body of the winch or the cable, or a break somewhere inside the winch motor.
might be worth removing the whole thing and starting again.well, that was a bad idea!
hi mate , long time no speak .Originally posted by surfenstein View PostSteve is it constantly live or only when the button is pressed for forward or reverse.I have known the bottom locknuts to come loose under the cable terminals and this causes the cable to turn a bit and the live terminal to touch the casing.
its only when the buttons are pressed in either direction.
it was working fine on wolfracers truck , then after fitting it to my truck this morning its shorting out , theres a piece of rubber in between the terminals and the winch body so cant see it touching there . ill have to strip it off and have a good luck when i get 5 mins and my knee has recovered from me dropping the winch bumper and winch on it
im starting to think it may be inside the winch itself as i cant see it touching the body anywhere . bugga more work to doOriginally posted by muddle View Posti know nothing about winches or the way they're powered, just had a thought is all.
run a thick cable from the body of the winch to a good earth and problem solved!!
