what's the best way to remove decals?
  • what's the best way to remove decals?
    Need ideas, mines crap, all old, crusty and bits missing. I tried with a hairdryer but it leaves all the glue behind. It will only come off in small pieces as its all cracked.
    Any of you done this and have any tips I could use?
    well, that was a bad idea!
    I used spray carb cleaner and some rags and plenty of elbow grease.
    Or a caramel ? Wheel in a drill
    Eat.Sleep.Surf.Repeat.
      Caramel wheel, loads on eBay and they work perfectly.
        Is the wheel just for the glue or the decal aswell
          All of it
            i use the hair dryer then use wd40 on a cloth for the glue
            paul
            1992 imported surf 2.4 ssr-x
              Cool thanks chaps, do I need to keep the area wet like a polishing mop?
                i use a hair dryer for the sticker then wd40 on a cloth for the glue
                paul
                  paul
                  Quicker with a caramel wheel!
                    This video shows an angle grinder version, but the most common caramel wheels are for electric drills.
                    https://www.youtube.com/watch?v=To5qmCqY6S0
                      Wow! Do the smooth ones work the same, that one was all angular and angry.
                        The one in the video doesn't create as much heat as the smooth versions.
                          Oh right, ill just keep the speed low and the movement fast till im used to how it works. Thanks chaps.
