can anyone tell me what tyre presures i need when towing a caravan & fully laiden,as its not in manuals ??
tyre presures
Iv been doing a lot of research on tyre pressures from 25 psi up to 33psi.
This is because i was still having a poor ride after spending a fortune on tracking and wheel balancing etc.
Iv found that after doing a hundred miles on each pressure ,that 29.5 psi all round gives a much better ride than the 32 psi that most people are running.
I have 31x10.5 x r15 tyres but my suggestion to you is try a few tyre presssures and find which is best for you. It seems to have sorted my wheel wobble problem too.Dont ask me how but it has and has also knocked my vibration problem on the head too.
If may not work for you but did for me!!!!
I always work better wet
Its why I became a plumber!!!
your tyre wall should state info such as max tyre pressure when cold etcOriginally posted by colsopcan anyone tell me what tyre presures i need when towing a caravan & fully laiden,as its not in manuals ??(\__/)
I run 31 on the Bullet whether towing or not. I've tried various pressures from 27 to 40 (40 was an accident involving a BP service station...) and 31 runs best for me. 27 was a bit wallowy and 33/34 too hard for me. I drop that to about 18 in the really muddy stuff... on BFG A/T's 31x10.50x15.
However, I just checked the 4 runner and that has 29 in at the mo and feels fine - on Khumo M/T's 31 x 10.50x15
All a matter of personal preferance...
Linda
www.4x4toys.co.uk
