egr blanking plates
    Originally posted by Webbo View Post
    If its any help I can get some laser cut out of Stainless if someone can let me know the dimensions, I willl get a price.
    Hey, Dave. I would be interested in a pair of those.
    " Time wounds all heels ".
      What thickness ? Would 2mm be OK ?
        OK Mick, working on it. Ta.
          I used 1mm but sandwiched between the wrap around pipe and the manifolds.
          Someone else here reckoned 6mm or 8mm if you wanted to lose that pipe. I'd probably get a manifold off a 4runner and just blank the inlet if I was going that route though.
          Whilst I've got your attention how much (rough idea?) to knock up a stainless front downpipe with the flange in 2.5" tube ? I'd have to send you up a sample as it needs altering from standard.
          Cheers,
          Rob.
            I used 6mm steel,and that seems to be OK,but I lost the EGR altogether.When I used to floor the throttle and small puff of black smoke used to puff out,but now it's clean,however that could be down to the two kilos of crud I washed out the inlet manifold
              Somewhere between 4 to 6 mil would probably work best, Dave.
                Ok I will have a go and see what I come up with, thanks Mick.
                  So the 3 Litre needs one of each ?, are the dimensions the same for the 2.4 ?
                  OK, so what length of M8 bolts do I need to supply as I will do those as well as a complete kit... Thanks.
                  • #24
                    Yes for the the 3.0, no idea about the 2.4.
                    Any idea about the exhaust downpipe in stainless ?
                    • #25
                      I thought about doing one when I replaced mine, but went for the genuine Toyota one with all the covers on.
                      • #26
                        Mine needs to be modified to clear the lift so was hoping to do it in stainless and transfer the heatshields over. No worries I'll try a fab place place down my way.
                        • #27
                          Thanks Got that drawing transfered to cad, can you please let me know the length of M8 bolts, and I will supply those with nuts and washers also in stainless. Thanks.
                          • #28
                            do anyone done a write up of how to remove fully the egr on the 3l (1994)? with pics? i want to do it but don't want to mess up!
                            thanks
