Today...
    Sent from the iPad you "lost"
      Originally posted by slobodan View Post
      Hope so!
      Non intercooled nothing.
        Today I had two small incisions made, in either spud. There will be no more young GWH's.
        One has a rather sore set of said spuds.
        That is all, carry on.
        Hey, Gra. Was all that intricate scalpel work on the aforementioned potatoes some kind of a practice run for having your b0llocks chopped?........
        " Time wounds all heels ".
          Mick...it was.
          All I can say is day two...sore.
            Bought apples fa that barrow before.
            Worth it in the long run Graham
            Brian
              Cheers Brian.
                Missile to silo...check.
                Ignition on...check
                Houston we have lift off...checkity check CHECK....Ahem.
                All appears functional...carry on.
                  Thanks for sharing...
                  Using the medium of song to express your actions...
                  You mean to say the "sky rocket's in flight..afternoon delight"?
                  If so, how are you typing and "doing the doo like betty boo? Are you using your dictaphone?
                  www.johnthebuilder.info
                  • #24
                    Hurrah !!
                    • #25
                      Probably not cos apparently it's so small it'd get stuck between the numbers on the keypad!!
                      (So Jo told me)
                      • #26
                        Originally posted by Balllsy View Post
                        Try not to sit on 'em... that will only be done once You'll make dam sure you don't do it a second time
                        That's kind of funny from a bloke called balllsy!
