Originally posted by TonyN
									View Post
3.0 d4d
Cheers. I've just spent the last half hour reading up about it on the net. Also found an interesting South African forum about the almost necessary usage of different filters and water traps. The idea is that any water going through an injector nozzle at the D4D's 2000PSI will vapourise at that pressure and can even possibly pop the end of the injector nozzle off into the bore. Also minisule particles of dirt which are small enough to bypass the factory filters could congregate into bigger pieces and cause issues.Oh Nana, what's my name?
We've got a customer with dodgy seals, at the moment. He kept wondering why his dipstick kept popping out when the engine was revved.......still hasn't had the seals done, though! Just waiting for the phone call!Originally posted by TonyN View PostThey have iffy injector seals from new, so they leak diesel into the sump and the oil gets diluted and they blow themselves to bits.
Have changed 2 complete motors this year. Toyota will cough up the £6K odd for a new short motor if you make a fuss and do your research.
If you get one change the injectors seals to the new type and they are all good.
Wasn't overly impressed with how full of crap the intakes get from the EGR, for a 5 year old engines, and they are stupidly electronic based, so much so when replacing injectors, we had to get each injectors serial number programmed into the ECU to get it run properly. Not the sort of motor you can fix in the middle of the desert.
Originally posted by dieselboy View PostCheers. I've just spent the last half hour reading up about it on the net. Also found an interesting South African forum about the almost necessary usage of different filters and water traps. The idea is that any water going through an injector nozzle at the D4D's 2000PSI will vapourise at that pressure and can even possibly pop the end of the injector nozzle off into the bore. Also minisule particles of dirt which are small enough to bypass the factory filters could congregate into bigger pieces and cause issues.
See what I mean, diesels are shite!
