Just because the temperature gauge doesnt move, doesnt mean its not warmed up enough. If your'e going to go down the fuel route good luck...but it aint that.
not just going off the gauge but would the engine really warm up in under a minute after being stood all night
just trying to eliminate things as the one constant factor is get it some revs and its literally feels as if its blowing something through (when its not work i would say it also runs a little rough and bit noisier)
thats how im doing it mate ATF is nice and red doesnt smell only a couple of months old has been changed twice since problem started (first one was nice and brown)
wont pull away in drive have to drop to low however sat with engine revving this morning as pulled off fine did the same tonight its as if something is causing a blockage
Just so you don't spend money on stuff you don't need. If you heat the filter or the tank all the fuel lines will remain cold. Unless you're using veg or have recently relocated to the Kuiper Belt it's not that.
only reason I was thinking off heating was to be sure there was no waxking etc (i know its not really cold enoughbut read somewhere about desiel monsters in the tank lol)
It's the home of many things including Goodcats sense of proportion, the sphincter that once existed between Thriftys brain and his posts on Internet forums and a large cloud made entirely of Biohazards arse gas which will finally achieve sentience in 2014 before making its slow way back to earth and annihilating us all the moment anyone lights a fag.
