anyone know where i can get one of these
  • anyone know where i can get one of these
    hi guys anyone know where I can get something link this
    http://www.ebay.co.uk/itm/Fuel-heate...item27c15913de
    cheers
    yeah,ebay !
    Bunkle
    Fox Hunting is Dangerous
      lol cant see any in uk
        cheers
        http://www.diesel-therm.com/vegetable-oil-kit.htm
        this is what you need if planning to run on pure veg , problem is it in germany and quite expensive
        Everywhere I go .... Im there
          cheers mate its im not looking at running any veg but think i may have an issue with waxing or varnish
          cheers
            Actually, going on the experience of many, you don't actually need to make any mods to run the Surf on pure veg if you wish to*
            To the OP.: Can you be more specific about your problem you're trying to solve? (Also for the record that ebay seller will ship to the UK, not that it is likely to sort a lot of problems that people often buy them for)
            *Unless its a petrol
              does anyone think something like this wrapped around the fuel filter would work not sure if it would get hot enough
              http://www.ebay.co.uk/itm/Motorcycle...item5647e20d9f
              cheers
                cheers
                A hint at what you are trying to achieve might be an idea?
                Diesel and especially winter diesel will not start to wax untill the air temperature drops to around -15 or so.
                Why would you want to have a heated fuel filter?
                Eat.Sleep.Surf.Repeat.
                  Basically my truck will not set off in drive have to drop to LOW and manually go up the gears
                  however for last few days I have sat with the revs at round 3000 for a minute or so will pull off in drive and was fine all the way to work has done this a few times now is also ok after a good run on the motorway almost as if there's a blockage or something that needs blowing out
                  so just trying to rule out fuel issues
                  have installed a non-return valve just before filter
                  cheers guys
                    It Is not fuel related. If you have an issue changing gear until the engine is warm, my suggestion...again...is to look at the sensor that tells the box it is warm enough...or the box is uncle franked.
                    Non intercooled nothing.
                      where is said sensor (any chance of a pis so I know what I'm looking at) but not sure its being warm that the trigger as high revs just blows a bit of smoke and clears any "blockage" not really long enough to get warm as temp needle also doesn't move until a few mile down the road
                      cheers
                        Until th eengine is warm enough, it wont allow the box to change up. I dont know where the sensor is, a grown up will be along soon to say where.
                          cheers mate but revving it made it work and wasn't long enough to warm engine up so feels more like a blockage that is cleared by high revs
                          cheers
                            How have you checked the ATF levels?
                              cheers
                              Just because the temperature gauge doesnt move, doesnt mean its not warmed up enough. If your'e going to go down the fuel route good luck...but it aint that.
