Hi Guys,
I have a two pillar Laycock vehicle lift that Im using for my build. The unit has been sat idle for a while outside the workshop (its permanent home) but had been working perfectly until around seven or eight months ago.
In order to reinstate it I cleaned the pick up filter and changed the hydraulic oil before flicking the switch and hoping for some movement (no weight on it at the time). Alas no movement
The motor spins up no problem it is a model that has direct drive to the pump unit above the hydraulic reservoir that I could see and therefore no belt slip causing lack of drive to the pump.
There is suction at the pick-up point in the reservoir.
No leaks that I can see
Any ideas?
Does the system need to be primed or bled?
Headed to the yard tomorrow to see if I can work it out but some pointers would be VERY helpful!
Any ideas?
dunno any more details?
look in particular at the control valve service kit, im suspecting the ptfe/nylon ball is worn...its a long shot, but i bet that acts as a non return valve.
