Originally posted by si tate
View Post
Oooooh shiny shiny!!!
Originally posted by JD_975 View PostThose creeper boards are ideal working on these things, and they are pretty damn comfy too! Ideal to grab an hours kip on the premise of "working on the truck"If its not broke don't fix it.
Originally posted by si tate View PostI have 4 polished turds & a turd with castors?
Si, get it lifted and you can sit quite comfortably under there!"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
Originally posted by Wolfracer View PostYup, 4 "tyre blacked" standard tyres and a 3rd gen with itsy bitsy wheels... ;d;
Si, get it lifted and you can sit quite comfortably under there!If its not broke don't fix it.
"rear garage"?
How many garages you got?!
Mine's lifted and won't fit in the garage, but to be fair it wouldn't fit in before due to all my important stuff carefully organised, (randomly) throughout the garage floor space..."B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
Originally posted by Thriftyjust an observation, when are you lifting the roof on your garage so you can use your new toys? seems a bit low on roof height i do like the look of the crawler board though. nice purchase. im sick of getting cold shoulders and oil soaked shirts.If its not broke don't fix it.
Anyway, Yahoo'd it and got a right laugh. Some of the best ones were....
"If you hang it like an upside-down U the luck drains out and If you hang it like a U it attracts the pixies, elves and even witches who use it as a swing."
"On its side with the open end on the left or right.
Not with the open end up otherwise the devil can sit in it.
Not with the open end down otherwise the luck will fall out."
"As it was originally supposed to represent the moon; the correct way to hang it was with the opening to the side but tilted slightly upwards - that way it could catch any luck that fell and the Elves couldn't use it as a swing or a seat."
"By god you gotta keep it open end up boy so's the luck won't run out on the floor!!"
"If you hang it with the open end up (like a U), the luck will not run out.
If you hang it with the open end down, there will be a curtain of luck covering the door so the Devil cannot enter.
You can't lose -- as long as you hang it with seven nails, and don't drive the seventh one all the way in."
"Hang it up with the toe of the shoe pointing down....you want to keep your good luck inside of the shoe....
If you hand it upside down all your luck will run out..."
...........And so on.
I didn't think people believed in this sh*t. Sounds like they are sincere too
Nice new tools BTW. Bargain
Originally posted by GBV8 View PostCouldn't help noticing your Horseshoe and thought to myself, is that the right way to hang it? I was just curious.
When we moved here the garage had no roof or doors & was piled high with shite, as i was filling the second skip it fell out of a box so i though i'd clean it up & fix it above the doors, now im thinking if i should tilt it slightly.If its not broke don't fix it.
