Fuel heater relay
  • Fuel heater relay
    Hi guys anyone know where I can get a fuel heater relay from and also the small filters connected to vac pipes
    cheers guys
    I have a look in the garage tomorrow i think i have a relay
      if you have one how much?
      cheers bud
        No i have not .... only main ecd, glow plug, fuel pump and all the ones under the dash ...... Fuel heater must have been a optional extra with the winter pack
          thanks for looking mate
          doesn't look like I have the fuel heater on the filter only the cables on the bottom for the water sensor? but does have a spot for the relay in the fuse box so not sure what's going on there
          cheers
            I think most have that (mine does) but no wiring that I have ever seen, unless the heater is actually fitted.
            Nev
              was going to fit a manual override to the heater but cant now ah well will keep trying top get to bottom of gear change issues although new filters and vac pipes has helped fuel consumption a hell of a lot still hasn't fixed gears problems next port of call to check all earth cables if i can find them all
              thanks guys and further info would be much appreciated
              cheers Jon
