Auxilliary Temperature Gauges
  • Auxilliary Temperature Gauges
    I'm considering purchasing a digital temperature gauge along the lines of the ones fitted by Si Tate, Biosurf and Bogus
    I was wondering if they, or anybody else that's fitted a similar one, had experienced any problems with them
    This one looked alright.
    http://www.hiluxsurf.co.uk/showthread.php?t=73863
    Sent from the iPad you "lost"
      No problems to report with mine Bob, its still working just fine
      Сви можемо
        Mine was easy to fit but the built in volt metre is a little temperamental, apart from that the actual gauge is very accurate.
        Got it from R-Spec.
        http://rspec.co.uk/performance-gauge...perature-gauge
        You will also need the Adaptor for your top hose "38mm"
        http://rspec.co.uk/gauge-sensor-adap...r-adaptor-38mm
          Got it from R-Spec.
          What sender do they supply in the kit? Not the adaptor thingy .
          Is it a threaded affair ?
          Oh and Hi
          Eat.Sleep.Surf.Repeat.
            Oh and Hi
            Ye, threaded & ready to fit.
              Originally posted by slobodan View Post
              This one looked alright.you have to insert it into your anus but i quite like it.
              My temperature is just fine thank you Doctor
                Helloi fitted one of these at the begining of the summer
                http://www.ebay.co.uk/itm/Micro-Digi...item2566e77c5b
                And it always read about 10 degrees too low, i had to remove it and calibrate it in a pan of water with a kitchen type thermometer. It's better than the factory one but i'm still not happy and looking to replace it.
                One to avoid i think!
                Non consternationes.
                  Didn't you cry and report me to the mods for that the other day?
                  Strange guy you are.
                    Strange its just a bit of fun, if you cant take a joke dont give it out lolol merry christmas
