What can I do to help the front of my Surf now that it has a lift, larger and wider tyres?
I have the wobbly steering syndrome once again where the two front wheels are able to move a little more independantly of each other. I cured this issue before by replacing the four ball joints and the track rods. I think I'll have to do this again, but are there better or stronger parts available that can withstand having 33 x 12's? Are there angled ball joints available for us? I wouldn't know where to look?
I also accept that I may have been unlucky with parts. I've had past experiences with other motors regarding parts failing almost immediately after fitment. I usually use Roughtrax. Open to suggestions?
 ) The UJ's at the box and steering wheel end will let it move around plenty, apart from any actual pulling forces, I guess the rubber is more for taking shocks from pot holes out of what you feel at the wheel. So maybe not such a bad idea, I would like to try a poly one instead of rubber or nothnig at all though.
