Whizzing along tonight and all of a sudden speedo stops working....bugger
then OD light starts flashing...... double bugger
Kept going and just guestimated speed....... funny cus i got tugged last week for whizzing too much but as it was 1am and roads empty nice man let me go....
Not going to whizz as much till its fixed...
Found sensor check by mr bushwacker :
Look at the plug end of the sensor and you'll see tiny numbers, 3 2 1.
Apply 12v to pin 1.
Earth pin 2. plus the negative probe of multimeter.
Positive probe of multimeter to pin 3.
Set meter to 20v DC, switch on power supply and turn the plastic cog on the sensor. The voltage reading should fluctuate between 0 and 9 volts, if it doesn't then the sensor is stuffed.
Guess what i am doing tomorrow night in the dark.....
Apply 12v to pin 1.
