Good morning all for a while now I have been getting a knocking from the steering not all the time tho . So this morning got a mate to rock the steering while I had look at everything the only play I found was in the main shaft coming out of the steering box to the pitman arm when you rock the steering the shaft moves side to side dose this mean the box is fcuked? I did this test with the engine off just incase that makes a differance thanks in advance for any advise
steering box play ?
Yeah, just advised H his box is loose too. (snigger)
I don't know if there is a bearing or a bush in there, but its just wear. Usually easier to fine a good used one and bung it on.
R/T do a recon one which isn't the end of the world money wise if you want make it as good as new..
http://www.roughtrax4x4.com/?doc=16&cid=157&vid=1233
The white truck is really Jessie's Tony. So I'll tell her that you think her box is a bit loose. How's your life insurance...?Originally posted by TonyN View PostYeah, just advised H his box is loose too. (snigger)
Reckon that R/T one looks a pretty good price. Think that is the route I will go down...
I don't know what you lot are talking about...
Tony, did you say that the shaft was slipping in and out my wife's box when it should be nice and tight? Or was it that her box was grinding on the shaft? And did you grease it up? Just want to be sure I know what the problem was...
Also, she says that having you underneath has made a real difference - it was a much nicer ride.
Now anyway, what was it all you lot were on about again?
Its the emphasis on customer service that makes 4x4Toys stand out from the crowd.Originally posted by flounderbout View PostTony, did you say that the shaft was slipping in and out my wife's box when it should be nice and tight? Or was it that her box was grinding on the shaft? And did you grease it up?
