Ffs how fukin hard can it be!
  • Ffs how fukin hard can it be!
    To fit a poxy little stupidly soft unspringy 'C' clip to the drive shaft on my PS pump. 3 Feckin hours and I can't get the ba$tarding thing to go on tightly!
    I'd be as well putting a bit of fcuking chewing gum on there...
      ###### hell!!!
      I didn't think you guru's ever got pee'd off......
        I'm mellow
          Bugger, are you sure everythings seated properly, it shouldn't be that much hassle.
          Is this the smaller one 'behind' the gear that holds the bearing in?
            I'm mellow
            Wish i had something to be mellow with....(alcohol is out of bounds due to meds!!)
              It's the one that holds the bearing on the drive shaft. It has no springyness in it. once I open it up enough t get it over the shaft (so to speak) and slide it down until it sits in its wee groove, it rattles about.
              It's doing my nut in!
                Stick to the med's, Tony. Too much alcohol, and one can come accross as being a bit of an ar5e.....................
                " Time wounds all heels ".
                  Breath in!!!
                  Breath out!!!
                  Breath in!!!
                  Breath out!!!
                  And relax.
                    Poop, is this the new one or your old one? Maybe its just badly made and soft.
                      Perseverence, Andy. Think of what you're doing, now, as being "finger limbering up" excercises. Then you'll be ready to remove that window motor for me, later this week...........
                        It's the new one, from the RT kit. the old one is on its way to landfill!
                        It's 100% unspringy, so I can't see how it'll keep the bearing in place. If I open it up to slip it over the shaft, it does not spring back.
                          Oops, shit! That's tomorrow or Friday! Keep reminding me!!!
                            Hey, Andy. Don't forget my motor......................Hey , Andy. Don't forget my...............Sorry, is this too much?...........
                              Slid it on as tight as I could, then 'crimped' it in to the slot with pliers. Stupid set up!
