Good luck with the head mate. As I am the foremost head replacement expert on the forum remember these points.
(a) Put the fuel return & heater plug bar on in the right order.
(b) Put BOTH atf pipes onto the rad BEFORE starting the engine.
(c) After soldering a loose connector back on do NOT rest your forearm on soldering iron.
Anyone doing the above would be seen as a novice round these parts.
