Some time ago i changed the sensor that kicks in the electric fan.Been great, but ive has these over heat probs even when it kicks in. However, as the scrapper sensor had a spade fit i rewired to fit. It now seems that may be ONE of the factors causing my surf to over heat. ANYONE got a grey connecter type as apparently they are set at lower temp to kick in ?? (price ins post if you have)
2nd discovery is the middle hose (on it when bought) is a cut down pipe that didnt quite fit to suit the clip, so it blew off a few weeks ago.(possibly over time its worked its way off) New one due.
Back last year, an acquaintance who fitted a SS backbox to my Subaru, said he had a make do box that would fit the Surf and save the cost of a new or SS back box. Having mentioned to my other mate that the Surf seemed to get better MPG with a hole in the original back box, he explained that the back box i had fitted, may be to restrictive, so SHOULD i fit just a plain pipe as some on here have done, or am i going to cause emission probs and the MOT fails.?
Finally borrowed a Impact gun so Air Con rad coming off tomorrow, Is there any point in taking the rest of the air con out or just the rad.
After that, can get at main Rad and drain properly, refil as per needed.
Finally, had the head tested by my mate and IT HASNT CRACKED. Am i a lucky sod or not ?
nigel
nigel
