Tow bar alterations
  • Tow bar alterations
    After the recent trip to avalanche i have decided i need to do something with my tow bar. I was planning to make the drop down bit in the middle detatchable and leave and leave the rest in place to protect the rear bumper. From a legal and safety point of view would this be ok? The work would be done by a local fabricator as my pigeon sh*t welding isn't up to much. I Know removing it totally would be preferable but i do use it quite often.
    Dazza
    Non consternationes.
    Dazza
    This any use to you?
    http://www.ebay.co.uk/itm/Adjustable...item56427d0b8f
    This will give you an idea of what it looks like.
    http://www.hiluxsurf.co.uk/showthread.php?t=69008
    For simplicity, the best place to locate the electric sockets is probably through the bumper rather than wiring up extra sockets as per the above thread.
      Something like this
      Gone from 4x4 to 1x2
        Thanks for the links and pics but i was thinking more along the lines of cutting the drop down bracket from the box section that runs just under the bumper, then having it re-welded to some heavy gauge angle or channel section that can be bolted back to the box section under the bumper. This should give me about 4-5" extra clearance at the rear as my surf is standard height at the min, hopefully this would give retain some protection to the bottom of the bumper.
          Daz, step away from the tow bar, order some nylon blocks from expajun, plus 2 springs from rough trax and swap your tyres for some big uns. There's your 4 inches plus of clearance! only a day to fit all that with a bit of help from the boys...
          www.johnthebuilder.info
            Funnily enough, i am going to get some roughtrax +2 springs and probably bj spacers as soon as i have sorted out my cv's. The rest is just pipe dreams, at least for a while
