That looks good. I think I'll be able to fit one of those next to my subwoofer. Will I be able to slide the load liner across or will it be too tall? Also, is there any heat concerns? Meaning, the fridge / freeze would pull heat from inside and push somewhere else, or is it not noticeable?
Fridge in a Surf
another shot showing fridge on the slide I made
I run it off an auxillary battery and split-charge relay system.
My colorado (basic model) only came with one battery, but its like the Surf and has space for a second on passenger side behind headlight, so i fitted auxillary there.
Split-charge relay disconnects batterys when voltage drops below 12.8v
the waeco fridge also has a voltage sensor and cuts power when it drops below 10.? volts
never seemed to get too hot, the spanish sun was hot though!
not sure about load-liner, a smaller fridge might, but i think they are all the same height
my fridge sits on custom drawer boot storage system i made, so its quite high
Landcruiser Colorado
Sub. Forester
LIKE IT!!! however, what happens if your fire needs putting out after you've had yer cold beerz, and you just get a fizzle from the extinguisher?Originally posted by Sancho View PostIf you're going camping, just take a CO2 fire extinguisher. It could be useful for putting out fires but, more importantly, chills a beer in about 2 seconds.
oh, hang on, i'd probably be needing a pi55 by then anyway... problem solved!If you're gonna be a bear... be a Grizzly.
Looks good. I like what you have done there, a proper SUV!Originally posted by andycook View Postanother shot showing fridge on the slide I made
Oh Nana, what's my name?
