body lift
  • body lift
    Hi all,i was going to give my truck a lift this evening(50mm),could any of you guys tell me, can i go ahead with the lift without the bumper lift brackets and rad drop brackets,just to get the job done tonight,then at the weekend do the brackets? (E.G leave the bumper on for now?
    Not going to rest till its broke
    You have a 3.0l so don't need a rad drop as your filler cap is on the rad.
    Bumper will fit back on in original position, you'll just have a 2" gap between bumper and grill .
    So yes you'll be fine
      cheers animal,right im off to get it lifted
        Just remember to remove bottom half of fan shroud or the viscous fan will catch it when body is lifted
          did do mate,all went good job done,cheers for that,now on to the next job
            Is there a simple way to remove the gap between bumper and body ?
            Or is it accepted that it'll always be there and looks cool
            Not lifted mine yet but its a job for the new year......
              15.38 to 20.33pm!
              Is it that quick to lift a surf?
                Originally posted by Dobbslc View Post
                15.38 to 20.33pm!
                Two years, five months and just under five hours is a record!!
                  It doesn't look cool, it looks half arsed!
                  You need to make some plates to lift the bumper up.
                    I used 2ins angle brackets broken in half they are already drilled to drop the rad
                    worked a treat
                      worked a treat
                      Hi,sound real good
                      What lift kit etc did you use to do so quickly?
                        Completed a 2" lift at 10 o'clock last night, with a help from and thanks to BeamMeUp6375 (http://www.hiluxsurf.co.uk/member.php?u=52193)
                        Just need to sort some brackets for the bumper now, hopefully get that sorted in next day or so as I realy want to take the Surf for a "test drive" !
