I agree with Vince, I can't see how that bracket will work.
someone to make a panhard drop bracket,3rd gen
3rd gen style here......
http://www.yotatech.com/f2/please-re...bracket-38937/
Although even that doesn't seem like an adequate solution, it looks like the two securing bolts could rip the chassis bracket eventually. Something like that would be better welded on as well as bolted.
Originally posted by BUSHWHACKER View PostLook on-line for steel suppliers (Metals4U is one) and look for steel channel or 'U' section.
You'll need to measure the width and height of the 'U' part that you need to fit in the chassis bracket.
There will probably be a minimum length order, but if you make a few you'll get your money back plus a little extra.
EDIT: Is that definitely a 3rd gen panhard rod drop bracket?
It looks like it wouldn't do a lot to me and is relying on one bolt to be tight enough to hold it in place plus preventing lateral body shift??
My 3rd gen isn't here at the moment so I can't check, but I'm sure the drop bracket would be the same style as the 2nd gen.
Originally posted by BigBobE View Postdara have you tried kennedy steel in palmerstown dublin??? have a look on leinster4x4 as well as one or 2 of the members there do fabrication work as well...
if you want to get one made in kennedy steel i can drop into them with the drawing and get you a price...
thanks for the offer mate if iv no luck i mite get you to get me a price if you wouldn mind.
Originally posted by Albannach View PostI agree with Vince, I can't see how that bracket will work.
Originally posted by Albannach View PostI still wouldn't trust it! There's not much to weld to anything.
Probably not... but it is nice... I guess ride height changes over time and with what new toys are fitted, - and it means that you are mote likely to get it spot on with the benefit of a bit of adjustability when fitting and getting an alignment done...
If I ever get around to doing half the things I keep thinking about, I'd want an adjustable one...More Lift.
More Tyres.
More Engine.
