Just finishing building this...
It's a sort of half way house between a stripline and a TEM antenna. have been experimenting with it for a year or so now, and have just finished fitting cooling fans and heatsinks to the load and matching resistors as the uncooled ones... er... had a short and spectacular life.
It's capable of generating fields between the two plates of around 200V/m (volts per metre) of RF energy between around 10kHz and 30MHz - the lower end being very difficult to do with conventional antennas because of the huge wavelength and low transfer efficiency.
Quite pleased with myself as very few test houses can achieve this
