Parking sensors on a Surf?
  • dieselboy
    replied
    As a general "rule of thumb", if it makes you look like a tw@t, then you've chosen the wrong indefinite article.....Cheers....mick.
    If you can ammuse yourself during the most unsuspecting times at the amazement of others then in the words of Charlie Sheen you're most definitely "Winning!". I'm off to open that bottle of scotch.
    Leave a comment:
  • si tate
    replied
    Originally posted by Surf01 View Post
    It is the wife with whom I have an issue. She doesn't want to drive the Surf if she thinks she may need to park. therefore I have to take her on sshopping expeditions. That is my excuse and I am sticking with it!
    Fair point.
    Leave a comment:
  • Surf01
    replied
    Originally posted by si tate View Post
    If you know how to drive then you should be able to judge you surf when parking.
    Leave a comment:
  • Vultch
    replied
    I never know if "an" or "a" is the correct word to use. Americans seem to use "an" more than they use "a" which points in the direction which I am correct, mostly.
    "I fitted an £30 eBay set.." seems incorrect to me as it's more difficult to pronounce, rather than
    "I fitted a £30 eBay set..." sounds better, although being brought up around South London with a mixture of working with Essex people it's more like:
    "I-fittid-a firty-quid ebay set"
    huh...
    Leave a comment:
  • Tallyman
    replied
    Getting back to the original question, I fitted one to my Surf (I need it as both my accidents with the Surf have been slow speed backing into parked cars on my o/s!!!) and yes, the rear mounted spare is a nuisance.
    I found the n/s one wasn't a problem, as the sensor is far enough from the spare not to register, but the o/s one was too close almost anywhere on the flat back bumper I fitted it. Ended up putting it just on the edge of the bumper as it starts to turn towards the side section and there it doesn't register the spare but has enough rearwards scan to pick up anything out of view over the top of the spare.
    Leave a comment:
  • MWS
    replied
    Leave a comment:
  • MWS
    replied
    Originally posted by flounderbout View Post
    My wife just uses the spare wheel as a sensor. When it starts to lift the back wheels off the floor as it grinds up the bonnet of the car behind, you are about right...
    Using the tow bar is far more accurate Henry....Cheers....Mick.
    Leave a comment:
  • slobodan
    replied
    It's 'a'
    Now get back to booking yer flight.
    Leave a comment:
  • dieselboy
    replied
    Originally posted by Vultch View Post
    Its possible I fitted an £30 eBay set and their grand,
    to set up the distance beam direction I connected each sensor in turn to the control unit and rotated the sensor, (the beams are steered/slewed out of the sensor) until each sensor was pointing in the right direction and range.. works well
    Leave a comment:
  • si tate
    replied
    Leave a comment:
  • Rustinho
    replied
    Originally posted by mattisaLN130 View Post
    I often use the spare wheel as a parking sensor
    Didn't work quickly enough for me when I reversed into a tree a few weeks ago. I smashed the rear window and dented the tailgate.
    Leave a comment:
  • gary-r
    replied
    Originally posted by GRASSMAN View Post
    I've got a 2" sus lift, so the towbar stops
    the tyre leaving marks on the bonnet, if
    you listen carefully, you can hear their number
    plate crack.
    Gman.
    snigger
    Leave a comment:
  • Vultch
    replied
    Leave a comment:
  • GRASSMAN
    replied
    plate crack.
    Gman.
    Leave a comment:
  • flounderbout
    replied
    snap!
    Leave a comment:
