Fuel leak found.
  • Fuel leak found.
    A couple of days ago I was filling up and the guy in front noticed I had a leak from the engine. Had a look and though it was oily water, maybe air con condensate. When I went home found a patch of diesel outside the house where I had reversed out and a trail of spots down the street.
    I looked the fuel pump over but that was ok so took it to my local garage and he found that the throttle lever was rubbing against a injector pipe causing a hole. The holding clips were missing from the pipes so they had slightly moved causing the rubbing. Left it with him to sort as didnt want to drop any more diesel about.
