I have used the search and found alot of wheel bearing help but do you know if a pictorial diy has been done?
Wheel bearing change
Hello Marc....If it's fronts, these videos may help...www.turkov.com .....Cheers....Mick.Originally posted by marcdtr View PostI have used the search and found alot of wheel bearing help but do you know if a pictorial diy has been done?Last edited by MWS; 10 April 2011, 01:14." Time wounds all heels ".
Get the proper socket, wee bit more expensive than hitting the big nut with a hammer and screwdriver but the warm glow you will get from doing the job properly will be well worth it.
Preload is easy to set up and should save you having to buy another set of new bearings in 8 months time.Alan
