hi people was just thinking what is the worst 5 faults with our beloved trucks.
and what can we do to try and overcome these faults.
i wonder
cheers
vince
Weak ARB clamps on the rear axle.
ATF cooler in the radiator.
The handbrake position. (2nd gen)
Rear seat release knobs. (2nd gen)
The vacuum part of the ADD.
ok so far fit a v8 if thats what you want,
make and fit a open upwards tailgate mm will think about this one.
nut behind wheel ,make the missus drive
rusty rear 1/4 bumpers, have now made a mould for these(gen2) will let you all know when i make some fiberglass ones at the end of the month.
rear diff seals well there are plenty of seals about how about finding size out and see if there are double lip seals out there to try.
keep the faults commin
Weak ARB clamps on the rear axle. cant comment at mo
ATF cooler in the radiator. could a motorcycle oil cooler rad work
The handbrake position. (2nd gen) pass at mo
Rear seat release knobs. (2nd gen) are these a problem
The vacuum part of the ADD. do you mean the hose if so changes all mie for speedie type fixing with poly type hose
