Hi there folks.
I'm having a wee bit of trouble fitting my panhard rod drop bracket (4crawler one if anyone is interested).
The problem is that I can't seem to shift the bolt at the top end of the panhard rod (ie drivers side). The nut has come off easy as pie but the bolt doesn't seem to want to shift.
I tried loading up the back end as much as possible given what I had easily available at the time (wheel, big f00kin' heavy trolley jack and two large adults) but the bolt STILL didn't want to be hammered out.
Since I've packed up I've thought that maybe using spring compressors might help but has anyone got any other ideas to aid removal of this bolt?
Thanks in advance for any help!
