fault codes
  • fault codes
    At/oil temp. T-belt. And left hand side light pressume its water in fuel filter all on at same and consant bleeping sound
    seems ok now but just happend whilst i was driving any ideas........
    Alternator is on it's way out.
      cheers for that nev.....
      I have put down to the fact that my belts are slipping a bit and it hasn't had good run recently. my air-con belt was looking a bit frail and bouncing about a bit so i just cut it off this wont cause any problems will it. I will replace it when i replace/tighten the remaining belts
