Little oil leak.
  • Little oil leak.
    Whilst faffing about under the bonnet the other day looking for the thermostat sender unit i noticed i have a tiny oil leak, its above the oil filter towards the back of the engine.
    Apart from the rocker cover gasket & the head gasket is there any other parts with oil flowing through them that could be leaking?
    Rear main seal?
    NAS Spec: 95 Defender SW gone but missed
      Condensed crankcase fumes dribbling out of the intake hose?
        Is it an easy fix, just replace hose?
          Originally posted by 97T4R View Post
          Rear main seal?
          That sounds expensive, anything with the word "main" in it means £££££££
            Pull off the intake ducting from the turbo to the throttle body and see if there's oil lying in there. Wipe it out and re-fit.
              Cheers mate, i'll have a look at the weekend when i fit the new sender housing to the top hose & hopefully have the new gauge up & running.
