Veg oil knowledge check
  • Veg oil knowledge check
    A mate of mine wants to start using veg oil in his Hi-Ace van (T Reg) and his Colorado (S Reg). He's asked me if it' OK to use it in both vehicles, I just want to check the advice I gave him.
    So my question to you, is the same as his question to me. Is it OK to use SVO in both those vehicles?
    i know of people that run a hi-ace vans on veg
    and a guy i dont like runs his 02 plate landcruser on veg
    so i would say yes
      AS FAR AS I KNOW, it's fine as long as they're not common rail. But what do I know. The Colorado will be a 1KZ won't it?
        Yep, I think so.
          Originally posted by JUDWAK View Post
          i would say yes
          Cheers George.
            As long as they're both diesels there'll be no problems.
              That's the first thing I asked him!
                There used t be a databse on the biotuning website that was a reasonable guide but it seems to have vanished.
                There is a rudimentry and anecdotal one here http://www.vegetableoildiesel.co.uk/...base/index.php that may help but otherwise its really a case of looking for a few who have done it in their own if you can.
                  Try DieselBob's website. It usually has a long list of vehicles suitable for veg. At least it used to.....
                    My 1KZ-TE runs fine on 95% SVO, 4.5% petrol 0.5% 2 stroke oil most of the year. Ran 50/50 with diesel in the big freeze.
                    Presuming the Hi Ace runs on the same Denso fuel gear, shouldn't be a problem.
                    Does take a tiny bit longer to start from cold,maybe 2nd turn of the key, and will run quite lumpy if engine idles once the cold start has kicked out, but fine once engine up to temp.
                    Just my experience..
                    3rd gen 3.0 SSR-V '98 R
