a complete pain to get out
mine's leaking somewhere, and it's not the top cover ... can't really see where at the bottom or back somewhere
so have ordered the seal kit which I hope will fix it. Of course it MIGHT be the big o-ring between the aluminium part and the distributor block - which would a diesel bob job and ?~300 quid
so do I change all the seals I can and put it in again .. in which case if I'm unlucky it'll be out again for a diesel bob job
or do a diesel bob regardless
or get a replacement pump from richard instead
if you could change in in ten minutes then the debate wouldn't be as bad, but it takes a whole day in reality to get out
rossyroo
rossyroo
