Whats involved in doing this? Will I need to pull my half shafts out?
Replacing drum back plates
I didnt need to pull the shafts all the way out only enough to clear the splines. Thanks for the link. Think I'll need to pull the shafts completely clear to fit new back plates then. Great. Least I can do that leaky seal as well.Originally posted by BUSHWHACKER View Post
						Oh Nana, what's my name?
When you get the shafts out you can give the bearings a spin and enjoy the horrible rumble , you will need to get new ones pressed in. I thought mine were fine, only a very small leak on one side, I got new shafts built up with new bearings to simply swap them out, the difference in the amount of play in the bearings was incredible.Alan
