axel code's for front diff on a ln130
  • axel code's for front diff on a ln130
    hi all i nead to get a new front diff for my surf 2.4 ln130 on a j plate. i can get a diff from a ln130 on a j plate but it is off a auto and my surf is a manuel. so can sone one in the know please tell me if the diff out of a 2.4 ln130 auto swop in to my manuel... rsvp asap as the boy is closeing on thu and will not reopen his workshop till the 4 of jan 11 as he is spending xmass in the sun
    S S R G is the only way to surf
    scottish mud club member kerelawsurf
    There is a code, I don't know it.
    Count the teeth on the ring gear and the worm gear or spin the prop and see how many turns of the wheel to get the ratio.
    or search 'axle code'
    http://www.hiluxsurf.co.uk/showthread.php?t=46499
    Sent from the iPad you "lost"
      thanks bud but the the surf that is breaking near me has the g144 axle code n mine is g145 bummer ....................g144 is for the auto's n g145 is for the manual ln130 so i am still hunting for a g145 so if any one has one please pm me
        144 is an open diff, 145 is a LSD diff.
          i have a front diff from a surf with a code of g145 £100 terry 07759 272270
            ok i called you please pick up if you can or ring me when your free to speek bud is that price inc carrage bud
              All front diffs are open so it can be the right ratio but will not be LSD. G144 and G145 are the same ratio.
                so what you are saying is that i can put the g144 front diff in my surf that has a diff code of g145 well what do the boys in the know say to that one as i can get a diff less than 5 miles from home but it is a g144 front diff help some one in the know PLEASE comfirm PLEASE
                  Originally posted by jeff.fn02jwa View Post
                  so what you are saying is that i can put the g144 front diff in my surf that has a diff code of g145.....
                  Yes!
                    Yes!
                    yes it will work ? ok
                      Yes it will work.
                        will i have to change the the front drive shafts or is the shafts for the g144 & g145 have the same amount if teeth on them
                          ok any one else got any more in put on this subject please 'like will i have to change the front drive shafts or the hubs as i would like to do the job right first time and not waste time & money
                            saving this front diff g145 do you still want it? as i have someone else who wants it
                              Everything is the same, so you need nothing else but the diff.
