Snorkel Questions
  • Snorkel Questions
    Does proper aftermarket snorkel's pipework (before the wing) fit into existing holes in the vehicle?
    Would removing a big chunk of structural steel to fit a snorkel, cause problems with insurance or C&U regulations?
    IMO i would have made the hole in the structure slightly bigger so i could weld a piece back in to form a tunnel, this should keep the strength around the hole made through the strengthening brace down the inner wing, that way it would keep torsional rigidity even though a piece was removed, i have seen a few real bodged up attempts at this, and it occurred to me that if you take steel out you have to find a way of strengthening the structure back up again.
      Pah, it's only a wee hole in the inner wing.
      Alan
        Maybe he wants to replace the A pillar with a snorkel pillar combo
        Brian
          I remember I replaced a B pillar with a Surf sidelight/wing/bumper once.
          Alan
            I wouldn't have thought it'd make much difference. There is a reinforceing ring that you bolt round the hole you make with Safari and TJM snorkels anyway.
              i just put some reinforcing mastic around my hole
                Snigger!
                  it must get a good hammering eh to need reinforcing platic
                  or is that for another website
                    I take it you're going out with Stein tonight then ?
                      Do you mean like this.....
                      remove metal to allow drain pipe to pass....
                        Answers on a twenty adressed to me......
