Wanting to get the truck looked over......
Plan is to get the following looked at / done
Coolant flush & change, stat & rad cap change
Valve clearances checked (can any competant mechanic shim these if required?)
Check for knocking noise.
Get injectors & glo plugs checked
Check belts / pulleys
Get 4wd looked at, not sure it is locking.
Is there anything else that should be looked at on a 168000 Km truck, oil & all filters done regularly?
Ben
Ben
