Any tips?
  • Any tips?
    HAd an oil leak all over the drive way its concrete and badly stained I have cleared most up but left with the stubborn stain .....any hints on what to scrub it with that actually works to remove it??
    Mark
    fairy
    is all we used on oil and diesel
      Mark
      Battery acid!
        most of the diy stores do a brick/stone cleaner - its basically battery acid in a posh bottle.
          Engine degreaser and jetwash.
            Paint the drive black.
            Non intercooled nothing.
              http://www.stoneuk.com/stoneuk_guard...nd_sealer.html
              Al
                Move!
                Cheers, Nick
                "The force will be with you, always!"
                  Some say that sperm has a multitude of uses.
                  Some of it's qualities are well documented.
                  Some are yet to be discovered.
                  Sent from the iPad you "lost"
