Originally posted by Apache
View Post
the temp gauge mod
Originally posted by slobodan View PostYeah, that word 'simple' is in the wrong instance, sorry.Cutting steps in the roof of the world
Originally posted by POPEYE View PostIt goes better after the beer, i was thinking of doing this but as i got an aftermarket gauge i thought "sod it"Oh Nana, what's my name?
Originally posted by Apache View PostHaha sorry. I meant a basic one. You can get them from RS and probably Maplin as a bare LCD display that just requires a couple of resistors to configure as a voltmeter with a 0-2V, 0-20V, or 0-200mV display. The 0-200mV range would work fine as it will display 001 to 200, which means if you make a voltage divider suitable to display, say, 090 when the engine temp is 90 degrees, you've cracked it. It would be easier to do than describe.
So if I measure the water temperature with a probe or thermometer or something at the same time as measuring the voltage being sent in relation to that temperature sent to the guage to make the needle move then if taken at various tempratures from cold to operating temp that will give me the current per deg C and can calibrate it from there?
Originally posted by Bayside View PostCheers Andy
So if I measure the water temperature with a probe or thermometer or something at the same time as measuring the voltage being sent in relation to that temperature sent to the guage to make the needle move then if taken at various tempratures from cold to operating temp that will give me the current per deg C and can calibrate it from there?Cutting steps in the roof of the world
