wishbone
  • wishbone
    Rob
    do you happen to have a 3.0 diff, mine could be on the way out? if you have could you hold on to it until next thursday? (goes into garage)if you cant I will just have to wait till another crops up
    Hi Mate,
    I'm assuming you're after the front diff ?
    What diff code is yours ? (check on the vin plate on bulkhead) LMK and I'll check it's the same.
    Holding it is not a problem - it's underneath a load of stuff in the garage
    Cheers,
    Rob.
      Cheers mate get back to you tomorrow
        Rob
        Axle/diff
        a343f 3295 hope this helps
          Yep it helps - you have a G295...
          The one I have is a G254 - the wrong ratio for your truck Sorry mate.
          Rob.
            f**k
            cheers mate
