right couple things is there a problem with my rear diff 1st off not sure if it'd an lds or not and dont know how to tell but then off roading the othere day i was getting tracktion when my mate also in a surf was not right when i'm driving along i can hear what what sounds wind blowing and i got no idea what it is
help again please
Was the window open?Originally posted by lukenemma View Postright couple things is there a problem with my rear diff 1st off not sure if it'd an lds or not and dont know how to tell but then off roading the othere day i was getting tracktion when my mate also in a surf was not right when i'm driving along i can hear what what sounds wind blowing and i got no idea what it is
cant read the hole of the code but she dose end in a 5Originally posted by gwh200 View PostThe axle code ends ( I think) in 5.
So it might say g245...but I may be wrong. The axle code is on your plate, front bulkhead.
now what would happen if the wrong oil was put in it ? cos i think the last block topped it up with 80w90 i think cos there was a bottle in the truck when i got it and the level is to the top
http://www.mudmuppet.com
thats lsd.Just drain the oil and put in some new lsd oil.I can't remember off hand the correct oil type though.Check the diff breather aswell as that may be blocked or siezed.Its a small cylindrical thing on the top of the diff to allow it to breath.If its seized that can cause diff probsOriginally posted by lukenemma View PostG145 thanks guyshttps://www.facebook.com/groups/henpals/
DRIVE TRAIN
Standard rear diffs GL5, SAE 90 for above 18 deg C or 80W or 80W-90 for below 18 deg C. 2.2 Liters
LSD rear diffs just use specific LSD gear oil.
Front diffs without ADD (not Surfs) are same as rear diffs above. 1.6 Liters
Front diffs with ADD (all 2nd gen Surfs) are GL5 SAE 75W-90. 1.86 Liters
Planetary T/case (Automatic and most manual Surfs) needs GL4 or 5 SAE 75W-90 1.1 Liters
Reduction gear T/case (MK1 Surfs, and manual 4Runners) as above but 1.6 liters.https://www.facebook.com/groups/henpals/
right got the bottle and it says for lsd's :s but that still dont solve the sound thats coming from the back but just then when i was driving in the wet i could hear water splashing at the same time so is there a vent or something i can close or block off ?http://www.mudmuppet.com
