How should a 2nd battery
  • How should a 2nd battery
    be fitted into a truck that only has had 1 battery fitted.
    I thought it would be a case of taking a new battery lead from the live terminal of the original battery and putting it to the new 2nd battery and then on the negative side earth that to the body.
    The guy who just asked me was told if it was done like this then it would catch fire.Could someone explain for me the best way to connect up a new 2nd battery please
    lol, noooo, thats how twin battery Surfs are wired up, its in parallel, stays 12V doubles the amps, wired pos to neg (serial) gets you 24v, same amps
    (not sure if you have to wire the neg directly from batt to batt to make it work, or just to -ve on truck, someone else will know)
      Thanks Tony i have just posted back to the guy who asked.He should be happy now anyway
      I will see how the 2nd battery was fitted to my truck but as its dark and i ain't got a torch it was easier to ask first
        The positive cables are linked together. The cable runs accross under the slam panel from the driver's side to the other side.
        The negative just bolts to the inner wing on the passenger side.
          cheer Vince.How the hell someone could say it will catch fire is beyond me unless it was an absolute muppet doing it.
            .......exactly.
            Non intercooled nothing.
              electrickery
              if he was right every car ive had with twin batteries should be burnt to a crisp
              mind you ive had some big flashes on 24v plant hehehehehe
                Hey Gary!
                Get those photos of your GT40 on here pronto!
